otrfun
Dec 18, 2016Explorer II
IdaD wrote:The 3/4-ton Ram diesel (with 18-20 in. wheels) has an RAWR of 6,500 lbs., the 1-ton SRW diesel, 7,000 lbs. Both truck have the same FAWR of 6,000 lbs. Based on these RAWR's one could reasonably assume the Ram 3/4-ton diesel truck has only ~500 lbs. less payload than the 1-ton diesel (when both trucks are optioned/trimmed the same). Not familiar with the Ford and Chevy RAWR's, but I would assume somthing similar would also apply.looper wrote:They may already be of no concern. Some F250s are identical to the F350. Those that aren't only lack an overload spring, which can be added or supplanted with bags/timbrens. I'd also verify that tire ratings aren't an issue. Do some research and I think you'll be surprised how underrated your truck is on paper.
I'm not an expert nor did I stay in a Holiday Inn Express last night, but I have been researching the heck out of this subject trying to get us in a 5er with our 3/4 ton diesel Ford. (http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29114791.cfm) All I can say is, if you are going to buy a truck to tow with, get the 1 ton. If I had a 350 instead of a 250 all my issues would be of no concern.
As for Looper's comment, I agree. After a ton of research earlier this year we came to the same conclusion. For less a $1000 difference in price, to get the extra payload (both realworld and legally on paper), the 1-ton truck was, for us, the way to go. Of course, if you live in a state where registering/licensing a 1-ton pushes you over a certain GCWR threshold (when hitched to a larger 5r), then the 1-ton may not be the best overall option.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
