johndeerefarmer
Dec 20, 2016Explorer III
otrfun wrote:
Another thing the OP should keep in mind: Depending on your state of residence, you may have to deal with additional licensing and registration requirements for larger rigs. In a number of states, if the GCWR (truck GVWR plus 5r GVWR) exceeds 26,000 lbs., then special licensing is required. Other states like CA have different guidelines. Best to check beforehand.
For some folks, the licensing hassles are enough for them to pass on a 1-ton SRW or DRW. As a plan B they end up going with a 3/4-ton truck with a 10k GVWR and a 5r with a GCWR less than 16,000. If you happen to reside in a state where you can drive any RV, regardless of the GVWR/GCWR with a standard Class D operator's license, then, of course, not an issue.
Just something to consider . . .
What I did was to buy a 2017 F350 (NOT F250) with the 10k lb GVWR. I now have the full capability of a 1 ton but cheaper licensing and less regulations.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
