Itching2go
May 04, 2014Explorer II
jw of 4 corners wrote:
Our Jayco Designer 35CLQS had a small panel in the storage compartment near the water heater and pump with only two screws in it so that you could take it off to access the bypass. Not sure on your unit if it is the same.
I saw that panel, but wasn't wild about crawling into the basement to get to it, especially after mounting a cord reel in the vicinity that reduces the open space a bit. Thinking I'll just go ahead and bite the bullet, open the panel, and see what I can see. Hard to believe that they'd hide the bypass like that, though. I do appreciate the info. Thanks...
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
