Hiking Hunter wrote:
Cummins12V98 wrote:
Are you saying if you go over a curb your tires will touch?
No.
I had the TrailerAid left over from my pull behind TT, and it worked well for those wheels. But the wheels are closer together and the suspension is such on my fifth wheel, that if I pull (or back) onto the TrailerAid, the wheel that should be suspended is not off the ground by about an inch. That would prohibit me from changing a wheel without backing up, out of the "cup" of the TrailerAid to get more height.
I have a form of "Tandem Axle Bogie" suspension so if one wheel goes down the other goes up a bit. Clicky
That makes a lot more sense!
If i use the TrailerAid only the other tire won't hand without touching the ground. I put 2X material under it and the tire to be worked on clears the ground fine. I have the TrailAire suspension,
TrailerAid Plus works great!
