RockBottomRacin
May 11, 2017Explorer
beemerphile1 wrote:RockBottomRacing wrote:
I have a 2001 Fleetwood Wilderness 335G TH, converter removed by previous owner. Need to replace it, and I'm thinking about going inverter. I plan to go with 2 or 4 Costco 6 V batteries and I want to be able to run my TV/DVD without my generator running, and I want to run my fridge on 12 volt while traveling. I do have an onboard Onan 2800 Microlite and I want an inverter with an automatic switch between shore power and generator and inverter power. I would love to hear some recommendations and advice!
Thanks guys!
Unless you left something out, you could buy a regular smart converter like the IOTA, a 400 watt inverter and save many hundreds of dollars over purchasing an inverter/charger.
I also have a Parralex Model 80 power distribution box separate from my converter (if I had one). I plan to replace this box as well due to some water damage. Will the inverter you refer to plug into the wall socket or will it make the wall sockets work like I want them to?
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
