RedRider16's avatar
RedRider16
Need Water Heater Help
I have a 1988 Terry by Fleetwood and I’ve tried replacing the thermocoupler but the pilot light still doesn’t stay lit and I’ve heard that I would have to replace the gas control valve then. Anyone know where I can find a replacement for a Atwood gas control valve MPD-91043?
  • 25-30 Millivolts is what thermal couple puts out. What is lowest voltage scale on your meter? Should have a millivolt scale.
    Look at the valve end of the thermal couple to show where to touch in valve. It is very close to opening.
  • Stupid me, I over looked that the 200m on my volt meter for some reason but it’s running anywhere between 23-26MV. I tried to ohm test the valve again but I don’t think I’m able to reach far enough inside to hit the contact, it feels like I’m only touching threads or the ohm part isn’t working on my meter
  • Tomorrow I’ll get some wire to put into the coupler valve port and see if I can get a ohm reading
