zackyboy3rs
Jul 22, 2015Explorer
Need your input
Sunday I will be going down Black mountain. Am I correct that I should: 1. Turn off tow/haul 2. Manually put in 3rd gear 3. Turn on hazard lights 4. Hang on? Thanks
fireman41 wrote:
If the hill you are going down has a truck speed limit I would suggest that you go that speed. Just pick the best gear to hold u back with min use of the brakes and not red line the engine. High rpm are ok just bury the tachometer. Probably going to be 2nd or 3rd gear.
