zackyboy3rs
Jul 22, 2015Explorer
Need your input
Sunday I will be going down Black mountain. Am I correct that I should: 1. Turn off tow/haul 2. Manually put in 3rd gear 3. Turn on hazard lights 4. Hang on? Thanks
{tpc} wrote:fireman41 wrote:
If the hill you are going down has a truck speed limit I would suggest that you go that speed. Just pick the best gear to hold u back with min use of the brakes and not red line the engine. High rpm are ok just bury the tachometer. Probably going to be 2nd or 3rd gear.
Just for my own edification. If your burying the tach and high rpm are ok, how is this not redlining the engine? Or are saying its ok to run the rpms high...just not too high?
Seemed contradictory to me, thats all.
