md_procouple
Oct 24, 2016Explorer
If your just stopping overnight, you can use a Flying J fuel stop, or a Walmart (if using Walmart make sure you check with the manager). if worse comes to worse try to find a spot on the end at a"rest area" so you can at least pull your bedroom slide out to use. Good Luck and Safe travel !!
About Fifth Wheel Group
19,027 PostsLatest Activity: Jun 19, 2019
