MFL
Dec 24, 2016Nomad II
RustyJC wrote:
If you're bound and determined to use a rail-mounted hitch and the truck has the factory prep package (pucks), then yes, the picture frame adapter is what you'll need. Bear in mind that even the 4x2 Rams sit higher than your 2006 plus the picture frame adapter will raise the hitch even more, so you may be challenged to get the 6" minimum bed rail clearance you need without winding up nose high on the 5th wheel.
I use the puck mounted B&W Companion RVK3600 set as low as it will go, the Trailair Triglide pinbox set as high as it will go and have 2" factory risers between the 5th wheel's MorRyde independent suspension and frame and I'm still a bit nose high, but our 2016 Ram is a 4x4.
Rusty
Good advice!! There is often hitch height issues using the pic frame adapter. IMO, sell current hitch, save the cost of adapter, and purchase puck ready hitch like Rusty has.
Jerry
About Fifth Wheel Group
