goducks10
Mar 31, 2017Explorer
Lantley wrote:
With the thought that the Andersen is more like a typical 5'er hitch.
Is it also more susceptible to chucking because nothing pivots or moves?
If chucking is the issue wouldn't a air ride pin or an air hitch like the BD3 be the best solution.
I imagine you need a way to absorb the chucking motion.
I used to have a B&W Patriot but have switched to the Andersen. Mines rail,mounted. There's absolutely no difference in the way it tows my 5er compared to the B&W. Only difference is it's about 100lbs + lighter. I'm also using the same MoRyde pin box thatI used with the B&W. I still have the same "once in a while chucking" with both.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 12, 2026
