laknox
Apr 14, 2017Nomad
RCMAN46 wrote:laknox wrote:MFL wrote:
IMO, the above is a big part of your problem. Putting the FW tank in the rear is just wrong, even though the floor plan may require it. I think weight up front will solve a lot, and an air cushioned pin box should help the feel, but not the problem.
Jerry
Part of my problem, is how do I find out =where= my tanks are, and =which= is which? I've yet to find a mfr that's willing to share this info, so the only way to find this out is to cut open the belly enclosure and look for myself. I've asked for this from Komfort, Jayco and KZ, and not a one would share the tank locations with me. The =only= one that's obvious on my current Komfort is the black tank, since it's right under the toilet.
Lyle
A trip to the scales will give you the most information for a possible cure for less than 10 dollars.
Cr@p. Why should I have to =pay= for info that should be freely, and easily, available. Not to mention the 3 separate trips I'd need to make between the scales and the dump station. :M
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
