jmtandem
Nov 03, 2013Explorer II
I suspect a drive down the street will fix the issue. If not, take the spring off the equalizer and replace it when adding some weight on the wheel (touching the ground). That should correct the issue. Why not add the EZ flex rubber equalizers at the same time as doing the wetbolts and axles? The EZ flex equalizers make a noticable difference in towing (at least mine does).
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
