fj12ryder
Nov 03, 2013Explorer III
jmtandem wrote:I'd have to second this suggestion. Adding the EZ Flex was the best money I've spent on my toyhauler. Not horribly expensive, but worth every penny. IMO anyway.
I suspect a drive down the street will fix the issue. If not, take the spring off the equalizer and replace it when adding some weight on the wheel (touching the ground). That should correct the issue. Why not add the EZ flex rubber equalizers at the same time as doing the wetbolts and axles? The EZ flex equalizers make a noticable difference in towing (at least mine does).
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
