laknox
Apr 29, 2019Nomad
mxdad777 wrote:Bigfoot affair wrote:
Short bed? If so Pullrite makes a auto slider that fits the pucks now.
It is a short bed, but the 5er I bought has the Reece Revolution pin box so I don’t need a slider. Thanks though for the reply.
If the Revolution requires a block in the kingpin, then B&W won't warrant their hitch; at least last I knew. Might want to double-check with them on this for their newer hitches. Hard to beat a B&W hitch.
LATER: OK, so I just chatted with Evette at B&W, and asked about the Revolution. They DO void the Companion and Patriot warranty if a Revolution, or similar, pin box is used, but ONLY on the single point attachment hitches. There is NO problem when using the OEM puck mounts. I did not know that.
Lyle
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
