mxdad777's avatar
mxdad777
New Duramax owner hitch question
I picked up a new 2019 GMC Duramax today and it has the optional 5th wheel/goose neck option installed from the factory. My question is, what hitch do you all recommend for the puck system? In my research I can only find 2 different models. One by B&W and one by Curt. Are there any others I should be looking at? You GM owners, which one do you prefer?
Thanks!
  • mxdad777 wrote:
    It is a short bed, but the 5er I bought has the Reece Revolution pin box so I don’t need a slider. Thanks though for the reply.
    I use the Andersen Ultimate in my 6.6' bed Duramax. With a Double Cab, the bed is a so called "Standard Bed 6.6ft". With a Crew Cab its a "Short Bed 5.5ft". My Pinbox is the MorRyde Rubber Pin Box and I must say the ride is great and I always recommend that combo.
    When I last spoke to Andersen about the MorRyde compatibility they advised it is their best combo but the Andersen Ultimate works fine for just about any hitch EXCEPT the Reese Revolution. For the Reese Revolution you must tow with the Revo in locked position such that the pivot point is over the ball and not at the Revo's pinbox spinner. When parking or in narrow turn situations it is ok to unlock the Revo but you just shouldn't do your regular towing with the Revo unlocked.
  • pcm1959 wrote:
    Hensley offers a puck adapter for the Trailer Saver BD3 (excellent hitch) and the heavier B5 will fit directly into the GM puck system without an adapter.
    Do yourself and your fiver a favor and get an air suspension hitch.
    I use the Reese picture frame adaptor with my BD3, $200 cheeper. X2 on the air hitch.
  • Hensley offers a puck adapter for the Trailer Saver BD3 (excellent hitch) and the heavier B5 will fit directly into the GM puck system without an adapter.
    Thanks!
    When you say "5th wheel/gooseneck option", are you referring to the 4 pucks or the ball in the middle of the bed? B & W makes a great product for both options. If it's the ball in the bed, you may want to consider the Andersen Ultimate Hitch as well if you're looking for light-weight and simplicity. I've used both and enjoyed them equally.
  • Bigfoot affair wrote:
    Short bed? If so Pullrite makes a auto slider that fits the pucks now.
