dbbls
May 21, 2014Explorer
You need to remove one wheel and take one hub off. There is a seal on the back of the hub, remove it. You will be replacing it so don't worry if you damage it. Remove the bearings and clean them up. Gasoline and a stiff brush work as well as anything. The rollers should be smooth and no rust. Feel of the race inside the hub. It too should be smooth. If either one is not smooth, replace both. There is a number on the bearing so just take it, and the old seal, to a auto parts store and they can match it up with new ones. Before replacing the bearings repack with high temperature bearing grease. Install the new seal, being careful not to deform it, and replace the hub on the spindle. Tighten the nut on the end of the spindle until the wheel is hard to turn. Back off 1/4 turn until you can install the cotter pin. Do this 3 more times and you are done.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 23, 2026
