smithrjd wrote:
Bought a new truck, and am wondering if it is time for a new hitch. The old hitch is a Husky 16K about 8 years old. No real issues with it, but it does have some wear on the pivot points. New parts seem to be an issue as it is no longer in production. I have looked at some newer hitches and don't really like the open pivot areas. What do folks think of the B&W Companion? Seems a bit expensive however. What is the best hitch out there now? Fiver is a 321RLTS Jayco Eagle.
I think I have the same hitch - purchased in 2003. I replaced the legs (uprights) with the newer design but the hitch head is holding up well. I keep a hitch cover on it when not in use and remove the hitch from the bed in the winter. It is heavy - get help taking it in and out of the truck bed now.
I remove the center pivot pin a few times a year and coat it with wheel bearing grease. I have not taken the side pivot points apart. I spray the side pivots with lithium grease and silicon spray frequently.
I purchased the new legs (uprights) from etrailer.com. I think you can purchase the new 16K hitch from them. The center pivot pin now has a grease fitting.
