Looked at some Sailun tires for a car the other day. Made in Vietnam which did not necessarily rule them out. The warranty seems to closely follow well known brands but the last sentence got my attention:
WHAT IS NOT COVERED UNDER THIS LIMITED WARRANTY
• Ride complaints after the first 2/32” of tread wear or replacement of 3 or more tires
from the same vehicle will not be accepted.
• Premature or irregular wear due to vehicle mechanical deficiencies or failure to rotate
the tires at recommended intervals.
• Tires on any vehicle registered, and normally operated outside Canada.
• Damage from incorrect mounting or dismounting of the tire, incorrect application, water
or other material trapped inside the tire during mounting or failure to balance the tires.
• Damage from over or under inflation, overloading, fire, theft, and defective vehicle
mechanical conditions.
• Damage from racing, off road use and misapplication of tire to vehicle.
• Damage from abuse, misuse, tire alteration or a tire that has been run flat.
• Any tires worn beyond the wear indicators. (Less than 2/32” remaining tread depth).
• Flat spotting caused by improper storage or brake lock.
• Damage from accident, chemical corrosion, tire alteration or vandalism.
• Tire which D.O.T. identification number and/or brand name removed intentionally.
• Loss of time or use, inconvenience or any incidental or consequential damage.
• Tires used on Recreational Vehicles (For camping & Motor homes, etc.) or in commercial
service.
