Rygar wrote:
lazydays wrote:
Had mine installed last Fall. I love them. I'll buy again when I need tires.
Hey lazydays, I have the same airbags in my Ford f350. I started running them at 50lbs with the Rv loaded but I was told that thats way too much and it should only be 30lbs. My Rv is rated at 2100lbs pin weight, what are you pumping yours up to when towing?
I run around 45lbs and my pin weight is around 2600lbs. I believe you can put much more air in them what you and I have and not exceed the specs. If it rides nice at 50 I wouldn't worry about it.
