Just sent rmoparman a PM on getting service.
Anyone considering MorRyde service should give them a call. They are great and willing to talk on the phone giving advice on which system to use. Their service is top notch. We had the Lippert cushioned equalizer that is similar to the MorRyde 3000 system. I never noticed an improvement after installation. Then we had MorRyde install the SRE4000 along with riser tubes to give enough clearance above the tires (SRE4000 requires 4") and to level the trailer. What a difference. We hardly felt a bump on the way home from MorRyde. That was only a 9400 lb trailer with 5200 axles, but we just had the SRE4000 installed on a 12,000 lb trailer with similar results. No doubt the IS system is superior, but it is also many times the money. Call MorRyde and ask for an estimate. We also had disk brakes installed at the same time as the SRE4000 at a different shop because MorRyde does not do axle nor spring work, which we also did.
