lucy6194's avatar
lucy6194
new stereo/radio
the radio in our Jayco only works while we are on shore power. As we do a fair amount of boondocking thought would be nice to have a 12v stereo system. Questions as to how to hook this up. Also will it be necessary to remove the old system and install the new one. Saw a Kenwood undercounter system on Ebay. would it be better to hire someone to install this. I'm very handy but electricity and me not to compatable.
  • I did some testing with my stock Kenwood and upgraded Kenwood Stereo. While turned on they both had a draw of about 1amp. While turned off, but display still on the draw was .5 amp. If I press and hold the Source button the draw drops to .08amp. This allowed the radio to remember presets and clock time. The long press on Source was equivalent to turning off power in car. I also tried this with the Kenwood deck in my Jeep. Have not tried the wife's Alpine.
    Is your installed system a Jensen combo unit (radio, DVD/CD, "home theater")? We have a Jensen unit in our WhiteHawk (downscale in price I know) but the radio (and CD function) does work on 12v only (it is also a fair power drain on the batteries). Might want to check wiring, mode switch, circuit breaker, fuses, etc. before writing off what you have. 12v. power isn't as scary as 110v. AC. I also have a portable radio in the trailer than runs on "C" batteries. Not concert hall quality, but entirely acceptable, just have to stick it in front of a window when inside the trailer for good reception.
  • RoyB's avatar
    RoyB
    Explorer III
    The Jensen Car radio install is pretty neat. They have the fader slide switches that goes from the front speakers to the rear speakers. This works out great for my setup where the front stereo speakers are inside the trailer and the rear speakers are outside for sitting under the awning.
    These pictures give you the idea of my setup...
    The Jensen radio is installed on this cabinet wall. They dont weight anything so install real good just cutting a hole in the cabinet thin 1/4-inch wall. It is wired into a 12VDC circuit. The antenna is mounted on the outside wall of the trailer. You can see the inside speakers here under my wrap around seating.
    The outside antenna is mounted at the rear of the trailer just were the hard sides meets the fabric windows. You can also see the outside speakers just above the tire.
    close-up of the radio install and outside stereo speakers
    The car radios will have the ignition switch 12VDC that will turn your radio OFF and ON using the auto ignition key. I wired this line into a 12VDC push button switch from radio shack and it is installed to the right of the Jensen radio installed in the cabinet. This allows me to keep my preset buttons on the radio active. Otherwise if you wire this line directly to 12VDC you will have to keep pushing all of the button to listen to your radio. I turn my radio on the regular way when we first arrive at a camp site then use the side switch to turn it OFF and ON when camping for two-three days at the camp ground.
    close-up of the Push Button switch and Car antenna mount.
    The other idea of installing a 300WATT PURE SINE WAVE INVERTER has its merits as well. This will provide you 120VAC power from your batteries and you can have two 120VAC extension cord drops one going to your home entertainment center location and the other going to your bedroom night table. I started out with a 150WATT Inverter, then went to a 300/400Watt unit and finally ended up with a 600WATT Pure Sine Wave unit. Seems like once you start liking the idea you want to add more 120VAC items like your HDTV , DVD player, small lights, small fans, cell phone chargers, computer chargers, the list goes on... Of course INVERTERs like to eat up battery power so a two battery setup is a must have thing but since you like to camp off the power grid like you indicated you may have already have more battery power on-board your trailer. All that is visible in my trailer install is this extension cord multi-outlet mounted on te top of the table or cabinet. No wiring visible anywhere.
    You just plug-in here whatever you want to use with the 120VAC power.
    This is an install idea for a typical smaller trailer setup...
    All of this submitted just for "food for thought"
    Roy Ken
  • You really have several choices. An inverter would be simple. A direct replacement to a 12 volt car stereo would be my next choice. Either would work fine.
  • Shouldn't be too hard to get juice from a nearby switch for a light. They are all 12 volt and run through the converter only two wires Hot and ground and with a tester you should be fine.
