Rolo2's avatar
Rolo2
New tires and brakes
Does anyone know where I could get my brakes looked at and new tires for my 5th wheel? I live on Long Island NY and have no idea who does work around here. Thanks.
  • W.E.S. trailer sales in wading river has always had a good rep. for service. Their is also Grand Am in Mastic, but don't know to much about their service dept.
    John
  • What ever you do, think saftey, if you are not comfortable doing it, don't.
    I do jack mine up and I was nervous at first, but you get better at it, nice to be able to watch someone and learn from them.
  • I place my bottle jack under the spring plate that's mounted to the axle. I buy new complete backing plate with new brakes already installed from etrailer.com
  • Rolo2 wrote:
    How big of a jack do you need to jack the trailer? We have a 40ft 5th wheeel.
    be very careful how you jack your trailer up you can bend an axle placing the jack on the axle tube most recommend placing the jack under the frame and raising the trailer from there, problem is you have jack more or higher to get the wheel off the ground .
  • A 10 or 12 ton hydraulic is plenty, but if you don't know where or how to jack it, you probably should hot be doing it yourself. At least not the first time.
  • How big of a jack do you need to jack the trailer? We have a 40ft 5th wheeel.
  • Discount tire or any good tire store will sell you tires. Brakes? Pretty simple DIY project. If your not capable, then a RV dealer will do it for you.
  • We don't have any idea in your area. What hubby did was ordered the tires had them delivered to our house then took the wheels off 2 by 2 and had them mounted and balanced and then took the other 2 and repeated the process. As for brakes I think any tire shop could look at them if not a dealership. Good luck and Happy Camping !!!
