Grand Design is going through typical growing pains. They can't keep up with demand and are in the process of building a facility for wall lamination and PDI.
GD has the same issues as all other mfg in the RV industry. Same poorly constructed items like faucets, stereos, Lippert items, etc as well as a shortage of good help.
Spend a month on the GD forum and it's evident that they're not immune to the normal run of issues. You can PDI a unit to death but it's still going to have failures because of the cheap items installed.
JMO but they're no better or worse than any others. They tout a better CS department and do get involved if necessary to expedite service.
FWIW I had the same EXC treatment from Northwood MFG and I'm sure others from other brands have had good service as well. But that good CS only lasts for one year. How many issues the unit will have after the 1 year warranty's up is the question.
To answer the OP's question. You should have no problem with your truck and that 5th wheel.
