http://www.palominorv.com/product-details.aspx?LineID=369&ModelID=2593#MainIf this is it then it's doable if you only use the trucks RAWR. You'll be under the trucks GCVWR and tow rating. But over on payload. JMO but as long as you don't load it to the max you should be fine. You just need to make certain that you're not over the RAWR.
If you weren't wanting to full time it would be easier to say go for it. I'm not a full timer but I would guess that a full timer will pack a lot more that a weekend warrior type. The 5th wheel certainly has the space, but the trucks the weak link.
