D_E_Bishop
May 12, 2019Explorer
59bisquik, I believe that if you are hooked up to Shore Power and Start the Generator, the transfer switch will give priority to the generator and disconnect the shore power.
This provides a certain degree of safety in that you won't have two dissimilar voltage sources trying to operate at the same time and that probably are not compatible. In the event that you are hooked up to shore power and loose power and start your generator, the power from the generator will not back feed into the shore system and feed the shore line back to the point of failure.
An electrician trying to repair the shore power failure could be injured or killed by the power from your generator not knowing that it was there.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
