RedJeep's avatar
RedJeep
New to TH and looking for advice on backing it up
I just upgraded from a 7.3L Excursion with a 36' travel trailer to a 2001 f350 7.3l crew cab drw with a 40' Heartland Cyclone fifth wheel.
First, some observations on going from a big travel trailer to a big toy hauler.
What a difference in towing. The TT would wiggle and wag with every breeze and passing truck. Very stressful driving. The X had plenty of towing power but going downhill or stopping quickly was also very stressful. It always felt like the trailer was pushing the truck around.
With the dually and TH 5th wheel I can say, "wow" what a difference in towing. Of course the TH is heavier but the 7.3L puts out enough power to get me where I want to go. The big difference is in towing stability (nothing pushes this rig around) and in braking power. It seems that the combination of exhaust brake and trailer brakes makes downhills runs and quick stops very comfortable.
But it aint all better. I absolutely suck at backing this rig up. With my old TT I could back it up into tight CG spots or driveways. I have heard that fifth wheels are great for tight turns, etc. But, I have not mentally figured out how to position the TH and then back it into a space.
Here is my question. I want to back the trailer into a driveway that is about 12 feet wide and plenty long enough. Typical driveway, it sits perpendicular to street so I need to back it in at an angle. I can come down the street from either side. Any advice on how to position the truck, trailer to start backing it up? Also, how bad is it for the tires on the triple axles when I back it up real sharp?
Thanks everyone for the help!
  • I'm going to try and describe what I find works
    Approach with driveway on driver side
    Hug the side of road driveway is on
    When front tire of trailer is at the leading edge of driveway turn away from driveway.
    When trailer swings to follow truck turn back straight.
    Truck should now be parallel to street and trailer should be angled (roughly 45*) and lined up to back into driveway.
    Start backing up watching trailer tires.......use them to follow the 'imaginary line' back into spot
    5'vrs are slow at first to react and then shift quickly so be ready to catch up and correct (lessen the turn angle).
    Practice and you will soon be squeezing that rig in between boulders and trees ready to drop the ramp.
