oilcan1001 wrote:
I cant get you a pic of my calculator stats, but here are my numbers and those who don't understand my numbers can plug them into the calc.
Also, I'm using my vehicle tag vs a VIN search for Specs (the VIN search gave me a 6830# RAWR which is 1860# more than the tag in door jamb
Front GAWR 4250
Rear GAWR 4970
GVWR 8800
GCWR 20000
On CAT scale with trailer attached (empty):
Front axle 4280
Rear Axle 5000
Trailer Axle 6420
CAT scale truck only
Front Axle 4160
Rear Axle 2860
Hitch GTWR 24000
Trailer GVWR 14000
Truck tires are new and rated at 3415# per tire
Hope this answers the questions
Have you owned this TV since new??
Those axle ratings look real low for a 1999 F250! The F250 Diesels were all HD models with a full floating rear axle, should have a minimum 6,000# rating on the rear axle, see if you can post a picture of you VIN sticker on the drivers door rear jam.
