shadows4 wrote:
Oilcan, your rear axle should be rated to 6084 lbs. The lower rating on the door sticker is probably due to the tires that came on the truck. Here is a link that you can put your vehicle vin in and it will give you a spec sheet on your vehicle. Just follow the link and select the vehicle tab to enter your vin.
I think you will be fine on your weights. Good luck, John
I tried your link, but it only gives me minimal data. GVW 8800 no axle ratings.
This is the
link I used, but not sure how accurate it is (3rd party I think)
