Bedlam
Oct 14, 2015Moderator
With the limited payload of the Tundra, you will need to watch your tongue weight. Many toy haulers have 1000 lb tongue weights or greater which may leave you with no payload remaining to carry anything in your truck bed once the two of you load up into cab. Depending on your truck's configuration, you may have less 1000 lbs payload because you chose every option available or you may have 2000 lbs because you chose a stripper model truck - The first thing you need to know is how much weight to do you plan to carry in the truck and how much is left for tongue weight. Then you can choose a properly sized toy hauler.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
