Bedlam
Oct 14, 2015Moderator
The Tundras are outfitted with 4000 lb rated front axles and 4250 lb rated rear. If you get the actual weight of your truck front and rear, you will see how heavy you can go before running into axle issues. This is not to say that your OEM suspension or tires are up to the task, but spring helpers are easy modifications as well as upgrading to LT tires.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
