Moki
Dec 29, 2013Explorer
Not that familiar with the Chevys, but I had the same problem when I had my 350. Found that the 350 used a 4" block and 250 used a 2" block. Went to the 2" block and 250 U-bolts and problem solved. Only negative would be less room for truck to settle under huge dirt or gravel loads. I put over 4,000 lbs in back and not even close to any problem. Might check out what's available in the Chevy brand. Inexpensive and not overly hard to do.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
