cairnwalker's avatar
cairnwalker
Newbie question: Flying J pump menu
Just made transition from gasoline MH and dinghy to F250 TD & 5W, hoping that truck diesel lanes would simplify the problem of finding accessible pumps. Well, accessibility is easy, but even after a 2K roundtrip from TX to NC and back, I'm still in the dark about a few things.
First off, the pump spout fits. And secondly, I have a FlyingJ card so I can pay at the pump. IF ONLY I could understand the interface: When I insert the card and enter my PIN, I get about 8 "choices" that are foreign to me. I don't recall all of them, but they include "tractor", "reefer", DEF, "choice" and some others, but none refer to the type of fuel. That, coupled with warnings about damage from fueling with the wrong product displayed on the pump kept spooking me, so I would inevitably take my card inside and do the "dance". I just said I wanted auto diesel and overestimated my charge slightly. The clerks were usually too busy to offer an explanation, and when they had the time, they didn't seem to know what I was seeing at the pump. A trucker in the next lane educated me as to the difference between the tractor and the reefer (which was the least of my questions), but otherwise not much help.
My main question: can anyone here clarify these choices at the pump when paying by Flying J card?
And my other question: are their multiple grades of diesel at truck lanes? Somebody said Diesel 1 or Diesel 2. What's the difference? What is comparable to the diesel served at the auto pumps.
Thanks so much in advance for any assistance.
  • Two Hands wrote:
    We get our diesel at the rv pump island at Flying J. No pump menu to fret over. Put your cards in and pump. My CEO/Navigator goes in to the cashier and prepays to make things even easier. And yes she gets the discount.
    Many flying j have no Rv lane.
  • The last few times I fueled up the Flying J RV Diesel lanes they capture 500.00 on my credit card that didn't clear for 72 hours when I only filled up with 60 to 80 bucks worth of fuel. I have a credit card I use traveling that only has 2500 credit limit and I do that for reason of being scammed. I get 5 tanks of fuel over couple days could max out that card when there was only couple hundred dollars of fuel pumped.
    The regular lines at the Flying J only capture 100.00....
  • We get our diesel at the rv pump island at Flying J. No pump menu to fret over. Put your cards in and pump. My CEO/Navigator goes in to the cashier and prepays to make things even easier. And yes she gets the discount.
  • As said above
    1. Insert card
    2. Select tractor
    3. Select next (asks about def)
    4. Asks for control number (your 4 digit code)
    5. Lift lever
    Done
  • Tractor is regular diesel fuel.
    Reffer would be road tax free red diesel, that if you are caught with that in your tank, you will have the IRS all over you, and you do not want that! That red dye will stay in there through several fuel fill ups, and will take a while to get rid of, then change the fuel filters, ect, and you still might have some left. . .
    DEF is not what you want in the fuel tank. DEF is like cow pee, and is used to regenerate a catalytic system on modern diesel trucks.
    The others? Stop at "Tractor" and get diesel.
    Good luck,
    Happy trails!
    Fred.
