- riltriExplorer
Likes to tow wrote:
Go to a home center like Lowe's or Home Depot, buy a section of the plastic fence post that is about 5 inches square. Mount it under your 5th wheel and use the plastic end caps to cover each end. I put a hinge on the appropriate end used a plastic gutter cut to length that slides perfectly inside the fence post. This is better than a square bumper!!
My bumper was too small for the hose, so we did the same thing ^^^^ Works perfectly and easy to install. - Go to a home center like Lowe's or Home Depot, buy a section of the plastic fence post that is about 5 inches square. Mount it under your 5th wheel and use the plastic end caps to cover each end. I put a hinge on the appropriate end used a plastic gutter cut to length that slides perfectly inside the fence post. This is better than a square bumper!!
- BurbManExplorer IIIThere is usually a compartment for sewer hose storage. Also the design on a fifth wheel provides a large storage area in the lower front behind the pin box, usually called the "basement". Plenty of room for anything you want to store in there.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
