IF you have 50# water supply pressure and have low flow inside rig then the internal check valve on your city water connection is jammed or the washer/screen in connection is clogged restricting the flow.
Turn off water, disconnect hose and check washer/screen.
If it is clean then problem is with the check valve.
The check valve is just a cheapo plastic junk......a plunger, spring with o-ring held in place with a plastic clip.
If o-ring gets dislodged it won't seal and the plunger can get cocked.
You have to remove city water connection assembly (remove outside screws) and disconnect water line at connection on back.
Then replace whole assembly.
Sometimes you can push in on end of plunger to reset it......but relieve any pressure on system before attempting.
