Was using the furnace tonite but noticed the fan kept running but the air from the vents were cool. Swapped tanks but didnt make a difference. Got propane at the cook stove. What should i look for?...
I do know the indicator on propane indicators can be bad. I've had several that just did not work. As far as heater my only experience is I had the board go out. I also know if you have run out of propane while heater is not, you will need to turn heater off and then back on.
