rdmotex3's avatar
rdmotex3
No hot water in kitchen
Hoping for some help. Just finished a week of “generational cold” here in south Texas. Five days of bitter cold with the lowest temp of 9. I did not winterize our relfection prior to the storm. I drained it well after our last trip but I have no doubt there was residual water lines. Also, I did not drain hot water heater. Today was first day with sun and not frozen so I hooked up the camper and everything seemed to work and no apparent leaks. However, the water in the kitchen only turns tepid and never hot. I found a blog about the outdoor shower valves could be causing an issue if left on. Went out to check and sure enough they were on! Problem solved!! Nope still only tepid water I the kitchen. After an exhaustive search online with no luck I posted this question on a Facebook group. The best thought from that post was the hot water line in the kitchen was still frozen. Possible? I guess but it seems odd that would be the only line still frozen. Anyone else have any thoughts or heard this before?
  • Either the hot water line into the kitchen faucet is clogged or it isn’t. It is something else. .
