lakeside013104
May 06, 2013Explorer
No hot water?
This is a new 2013 Bighorn #3685RL that I just recently took delivery of. The LPG side of the hot water system is working fine and currently all shut off. I wanted to test the 120V side of the H/W system and see how long it would take to heat up a hot water tank that is full of cold water. I and currently hooked up to shore power and have (metered) 120V at the household receptacles in the 5er. The 120V hot water switch that is in the inside control panel is on. The 15 amp breaker switch is on. The small on/off switch located on the outside of the 5er and inside the H/W heater access panel is ON. The hot water tank is full of water. After two hours in the on position, I still have no H/W. I pulled the small plastic cover off the heating element and put a volt meter on the two exposed wires. The meter reads ZERO with the entire system energized. Am I looking at a burned out element? Is there another switch or breaker that I am missing? I was at my selling dealer today, but the technician was off and no one else could answer these questions. I respectfully submit my question to this forum in hopes that the experience here will be able to help me. Thank you.
Lakeside
Lakeside
