Far-N-Sweet's avatar
Far-N-Sweet
No water in Kitchen
Made it safe and warm to Mississippi from Minneapolis all set up. Problem water is working in all the faucets but the kitchen. We do not recall turning any of the shut offs for the faucets. Checked for water leaks and do not see any outside nor in the basement. Any other suggestions we can look at would be appreciated
Far-Sweet
  • Far-N-Sweet wrote:
    Weather has been warm so frozen not the option. Not sure about the aerator. It is one of the faucets that has the push button to change from spray to stream. Is there another screen further down? Would I need to pull the faucet to find the other screen?
    Yes if it's a pull out type faucet there will be a screen at the connection between the hose and the hand sprayer.
  • Weather has been warm so frozen not the option. Not sure about the aerator. It is one of the faucets that has the push button to change from spray to stream. Is there another screen further down? Would I need to pull the faucet to find the other screen?
  • I agree with "hardcandy". The only time I had a problem with a specific faucet it was dirt in the aerator.
  • The aerator on the faucet is clogged (the screen) on the spout were the water comes out.
  • I've been living in my TT almost all winter and I have frequently had no water to the kitchen.
    On mine, there is a place where the pipes run against the outside wall and under my shore power cable box.
    They freeze in this location. I have to get in there with a heat gun to get things moving again.
    What is your temperatures like there?
  • Is it possible you have a frozen pipe? Perhaps a short run that has a cold spot in it? Only takes a few inches exposed to the weather, with a teaspoon of water in the wrong place.
