Old-Biscuit
Jan 11, 2014Explorer III
IF you have no water flowing when connected to city water source then you need to start at the city water connection and check the washer/screen in hose connection.....is it plugged? If not then your check valve inside the city water connection has jammed (probably damaged from freeze)
IF you have no water flow with pump turned on then you need to check that you have water in fresh water tank, need to check suction side of pump for broken/cracked fittings and or inlet strainer clogged/busted.
Then you need to check if pump motor is getting 12V DC power. If motor hummmms then it has power but pump end is damaged from freeze.
Your best bet..........get a fellow camper to come over and help you.
Living in an RV you should know where things are and what they do.
The fellow camper should be able to help you.
The pump will be close to/above the fresh water tank.
Open cabinets/pull drawers/look under bed......turn it on and trace down the hummming sound
We can't see....only guide and guess.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
