Roger10378
Jun 17, 2019Explorer II
Remove the pex from the check valve and you will probably be able to remove the loose bits of the check valve. Reinstall the fitting and you will be good to go. Just replace the check valve before it is time to winterize if you use the pink antifreeze. I do not use antifreeze when I winterize mine so I didn't replace the check valve.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
