chinook507
Dec 02, 2013Explorer
I built an enclosure around one of my fresh water tanks with 1" extruded foam insulation and a dual voltage 12 volt and 120 volt heater on the bottom and wrapped the lines with the felt roll insulation. Our Hauler has 2 60 gallon fresh water tanks and I installed a "T" fitting upside down and a ball valve to be able to drain my tanks when necessary. Also a small 1/4 inch ball valve on the vent line.
I have been up in some extreme temps hunting and skiing with no issues. I also dump a gallon of the Pink stuff in the black tank and make sure I empty the grey continuously.
About Fifth Wheel Group
