DCamp84ExplorerMay 06, 2017Noob water heater fill question.Quick question about filling the water heater. If I switch the valve in the docking station from tank to city does that direct the water directly into the water heater to fill it assuming the bypass v...Show More
corvettekentExplorerMay 06, 2017I would think that you need a hot water faucet turned on to let the air out of the tank.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Hot water heater question .....
