hbillsmith
May 06, 2017Explorer
corvettekent wrote:
I would think that you need a hot water faucet turned on to let the air out of the tank.
That is correct. When setting up camp, once water is available to the trailer (either city is hooked up OR fresh water tank has water available for the pump), go thru the process of opening your faucets and letting the air out. With a hotwater faucet open, the system will pull water from the hotwater tank which in turn pulls it from either the FWtank/or city.
CAUTION: Do not turn on the switch (Gas or Electric) until after you have pulled water into the tank. It is not advisable to heat an empty tank. With a hot water faucet on, air stopped spewing, and water now running. The hotwater tank is filling.
ALTERNATE: If you didn't drain your hotwater tank since the last outing then it most likely still has water in it. You still need to get the air out of the lines though.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
