SanMarMor
May 06, 2017Explorer
DCamp84 wrote:corvettekent wrote:
I would think that you need a hot water faucet turned on to let the air out of the tank.
I have been leaving the pressure relief valve on the wh open untill water starts flowing out. That is how I have been gauging its full so I can turn the heater on.
I do this to get air out of the tank, then I open the faucets to get air out of the lines. I don't drain water between outings, and I don't have air in the lines next time out. I only drain the whole system when I winterize.
OP, as long as your bypass valves are in normal position, your hot water tank will fill from whatever water source you're using, city for FW tank.
Mark
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
