GoneRVin wrote:
For those of you who have the same fridge, you might want to check your
Thermostatic Switch, they mounted mine over the slot in the cooling fin.
As if that is going to work real well.
just want a clarification. Are you talking about the thermistor attached to the cooling fins (small clamp) which senses for frig temperature??
We've got the same frig & see that temps periodically go up several degrees then go back down. We're assuming this is due to the temperature control periodically defrosting the fins as described in the manual, but it's a little disconcerting as you're not sure if there's something wrong with the fridge or it's doing what it's supposed to. Our last RV had a Dometic fridge & it maintained temperature pretty steady.
