dsnuggles's avatar
dsnuggles
Norcold error code
I have a 2017 Fuzion 369... getting ready for my trip and the norcold fridge decides to not work. It’s giving me a code of L1 OP..... any help would be great if not taking extra ice chest
  • Dirtclods wrote:
    Check all of your breakers and fuses first!! I actually opened up the back of my panel and cleaned the propane line igniter Note: It was pretty clean I used carburetor spray cleaner the blew it out with compressed air and then removed a black electronic box cover it had a newer fuse and the older glass fuse in there both were good I put it all back together and the darn thing was still flashing? I checked the breaker in the rig again!!? And one fuse was out so I replace it all was good. I started at the breaker panel first I really don't know how I resolved it but it's working??
    I checked all breakers and it’s all cleaned and I even also ran it on electric and propane and still nothing. I even tried resetting with magnet and the all still nothing. I will just have to use ice chest for this trip and it’s going into dealer on Tuesday for this.
  • Check all of your breakers and fuses first!! I actually opened up the back of my panel and cleaned the propane line igniter Note: It was pretty clean I used carburetor spray cleaner the blew it out with compressed air and then removed a black electronic box cover it had a newer fuse and the older glass fuse in there both were good I put it all back together and the darn thing was still flashing? I checked the breaker in the rig again!!? And one fuse was out so I replace it all was good. I started at the breaker panel first I really don't know how I resolved it but it's working??
  • You didn't mention if you're operating on electric or propane. If propane, you might try electric and see if you get the same results.
    The manual for my Norcold 1210 lists 4 possible reasons:
    Off level operation
    Insufficient, obstructed or downdraft operation
    Heat deflector blocking Flue opening
    Cooling system (fans) failure
    You didn't mention model, but you might search on-line for the manual for your model.
  • I found some helpful info when I input "norcold high limit switch is open" into Google.
  • downtheroad wrote:
    I found "high limit switch is open."
    Hopefully others will help you with a fix.
    Good luck with it and have a good trip.
    Yeah that’s what I found also but I can’t find out how that’s happening. I guess ice chest it will be for this trip.
  • I found "high limit switch is open."
