Just bought a new truck and now my fifth wheel rides slightly nose high. Axels are moumted under the springs and the pin box is as low as I want to adjust it due to clearances with the truck. It see...
I tow a Big Country with a 2010 Ram 4X4. Mine sits level with about 7" between the bed rail and the underside of the fifth wheel. Is you pinbox adjust as high as it will go into the the trailer frame? I had to move mine up when I installed a Trail-Aire Tri-Glide. They need an extra 1 1/2" or so over the std pinbox. You should be able to raise yours up higher.
