john_bet
Mar 06, 2017Explorer II
Second Chance wrote:My I ask why G rated tires on a 5th that has a GVW of 13995?laknox wrote:donewithtrucking wrote:
Unable to find out rating on my aluminum rims, 235/80/16. Putting on G rated tires that require 110 lbs air! There must be a code, because there's no numbers! Thanks
Often times the load info is stamped =inside= the rim, usually in the "valley". Means you have to break down a tire to find it.
Lyle
Mine were stamped on the inside "valley" as well - but a call to the Grand Design support folks who had my VIN and all the info on the components was easier. Your manufacturer may be able to do the same for you before you pay for the tires and/or pull a tire off a rim to check.
Rob
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
