fj12ryder
Mar 07, 2017Explorer III
JIMNLIN wrote:Well, they do recommend running less than sidewall pressure if the conditions warrant it. And most of the people running lower than sidewall pressures are doing it to make the trailer ride smoother. So Goodyear says it's okay.
My advise comes from actual experience(s).
With five trailers on the road 24/7 and 28 tires on the ground for over eleven years running (some with 2 sets a year worn out) gave me and my drivers first hand experience of the folly of over tiring a trailer and then derating that tire with low pressures.
Lost tread caps/tread separations/blisters from high heat at highway speeds and high rolling resistance were usually the result.
Best long term service will come from a properly fit tire with 10-15 percent reserve capacity to the trailers axle system.
Goodyear tire says it best...
Goodyear Tire and Rubber .... weighing RVs
Special Considerations
Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up
I take it those "five trailers on the road 24/7 and 28 tires on the ground for over eleven years" were all 5th wheel RV's which are relevant to our discussion. If they were Semi-trailers, not so much.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
